Company Logo (800) 853-2651 Shop Now
1030 injector
toolz
09-13-2014 18:28:43
Recently bought a 1030 advertised as having a bad engine. It's running great, no bubbles in the radiator, no water in the oil, and minimal blow-by. The problem is a knock in the upper end of #6 cylinder. I pulled the rocker covers today and adjusted the valves. All were very close to spec, and the engine is real clean inside. The knock is most obvious at low rpm, but is always there. Definitely in the head, and not lower. I can feel a noticeable difference in the #6 injector line in conjunction with the knock. Do I have a bad or sticking injector? Can this cause the knock? Any help is appreciated.
Dieseltech
09-14-2014 10:24:28
 Re: 1030 injector in reply to toolz, 09-13-2014 18:28:43
An injector that has a broken spring or tip stuck open will have a knock. A quick check is to remove the fuel line at the injector and crank the engine, if compression air blows fuel back out the inlet fitting, that injector needs pulled and repaired.
toolz
09-14-2014 21:29:54
 Re: 1030 injector in reply to Dieseltech, 09-14-2014 10:24:28
Thanks, Dieseltech. Tried that today, and the injector was OK. Swapped with another injector, and the knock stayed at #6, but I think I found the problem (or at least one problem). There is compression leaking past the #6 injector. I hope the seal surface in the head is OK. Ran out of time today. Will replace or anneal the washer tomorrow and see what happens. Thanks for all the suggestions.
casecollectorsc
09-13-2014 19:33:56
Did you check the power cell?
toolz
09-13-2014 20:25:40
 Re: 1030 injector in reply to casecollectorsc, 09-13-2014 19:33:56
I haven't taken anything apart yet, other than running the valves.
jerry he
09-13-2014 18:48:03
Put that injector in a different hole and see if the problem follows it.
toolz
09-13-2014 20:24:42
 Re: 1030 injector in reply to jerry he, 09-13-2014 18:48:03
I'll try that tomorrow. Never pulled one of these- anything I need to know?
jerry he
09-14-2014 05:05:59
 Re: 1030 injector in reply to toolz, 09-13-2014 20:24:42
If it is tight pry evenly from both sides. Make sure the brass seal is one per hole.
Today's Featured Article - What Price Enthusiasm? - by Anthony West. Quite frankly, for some time now restorers like myself have become more and more concerned about the rapid increase in the prices of old farm machines here in England. There is now a growing market for "As found" machines. Which as machines get rarer, has found the birth of a new industry....one of the "procurement agent". These agents appropriate as much old machinery as possible then inflate prices at auctions. So at what price enthiusiasm? We are now seeing poor machines which 3 years ago ma ... [Read Article]
Latest Ad: 4- D6 cat dozers and accessories [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
