Company Logo (800) 853-2651 Shop Now
Case 1070 won't start after rebuilt
Ramiro500
09-12-2014 20:39:33
Case 1070 won't start after rebuilt. It worked fine but we took it apart in order to replace one of the cluster gears. Everything came off including radiators and fuel pump in Order to sand it down to repaint it. We put everything back together, we bleed the fuel lines ,fuel pump and injectors but still no luck I'm guessing it's the timing on the fuel pump.
This post was edited by Ramiro500 at 20:41:47 09/12/14.
RGMartin
09-13-2014 06:01:42
 Re: Case 1070 won't start after rebuilt in reply to Ramiro500, 09-12-2014 20:39:33
I did this to my 970... It would actually run on its own after starting on ether, but had no power and smoked like a coal powered train.
timbernt
09-13-2014 05:43:34
Same thing happened to me on a 1070 about 30 years ago. It would start and run on ether. Turns out the pump was 180 degrees out of time.
Ramiro500
09-13-2014 09:46:04
 Re: Case 1070 won't start after rebuilt in reply to timbernt, 09-13-2014 05:43:34
can you walk me trough the process of timing the pump correctly I would really appreciate the help.
oldabe30
09-14-2014 10:23:29
 Re: Case 1070 won't start after rebuilt in reply to Ramiro500, 09-13-2014 09:46:04
Rotate engine until timing pointer is aligned with 20 deg. mark, remove valve cover over no. 1 piston, check push rods if they are loose your on comp. stroke if not your 180 deg off. Remove plug from timing cover and check marks on gear and pump.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
