Company Logo (800) 853-2651 Shop Now
1070 starter in 930?
MattLF9
09-12-2014 15:01:26
Hi guys.
Will a 1070 starter work in a 930 diesel?
Thad
09-13-2014 05:00:37
 Re: 1070 starter in 930? in reply to MattLF9, 09-12-2014 15:01:26
Different number of teeth on the drive gear between the two.
jerry he
09-13-2014 18:45:53
 Re: 1070 starter in 930? in reply to Thad, 09-13-2014 05:00:37
I think the nose of the starter is eccentric. If you look at the noses some have different offsets in the flange that contacts the block. Therefore they could have a different number of teeth as long as the distance between them is the same. I think the rule is diesel to diesel and gas to gas when it comes to ring gears and starters.
jerry he
09-13-2014 15:11:07
We have a 451 from an 1175 in front of an 830 comfortking case-o-matic and I am certain we used the starter from the 1175.
MattLF9
09-13-2014 19:23:31
 Re: 1070 starter in 930? in reply to jerry he, 09-13-2014 15:11:07
We put the starter in today and tried it and it worked! So things must line up or it would not have worked right?
jerry he
09-14-2014 05:11:33
 Re: 1070 starter in 930? in reply to MattLF9, 09-13-2014 19:23:31
You are in good shape.
MattLF9
09-13-2014 08:24:17
Can I just swap the gears over or is it more involved than that?
JW
09-12-2014 15:39:55
Pretty sure you need to change the nose if I remember right. I did it once trying to whirl one over faster. Don't remember it making that much difference, but it was many 930s back
MattLF9
09-12-2014 19:08:20
 Re: 1070 starter in 930? in reply to JW, 09-12-2014 15:39:55
Why does the nose have to be swapped? Is it a clearance issue?
Jw
09-13-2014 05:10:28
 Re: 1070 starter in 930? in reply to MattLF9, 09-12-2014 19:08:20
I don't remember, think Thad is right that the drive gear needed swaped also
MattLF9
09-13-2014 08:05:46
 Re: 1070 starter in 930? in reply to Jw, 09-13-2014 05:10:28
Ok I hope I can get a different drive gear somewhere.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
