Company Logo Shop Now
Case 377 rods
Pole climber
09-01-2014 15:49:44
Does anyone know the specs of a case 377 spark ignition rod and piston.
mEl
09-01-2014 17:21:45
 Re: Case 377 rods in reply to Pole climber, 09-01-2014 15:49:44
The pin size is my only uncertainty but someone has that info, the rod journal is 2.750 and the center to center length is 10.5" that should be the same specs as all Case rods including the small crank 504s. The wrist pins size increased as the HP increased.
I believe the latest pins were 1.625.
Big crank engines use a 10" rod with a 3" journal and 1.800 WP size
This post was edited by mEl at 17:23:51 09/01/14.
Pole climber
09-02-2014 05:00:58
 Re: Case 377 rods in reply to mEl, 09-01-2014 17:21:45
Thanks Mel, but I believe the apart ignition rods were a diff pin size then the rods u have given.
mEl
09-02-2014 05:23:36
 Re: Case 377 rods in reply to Pole climber, 09-02-2014 05:00:58
Yes, I know the later pins were larger, thats why I said the later pins, If you are considering swapping parts around I wanted to let you know the possibilities. I adapted a set of 4 5/8 Minnie pistons to 730 rods by sizing the 730 WP bushing to accept a MM bushing pressed in and sized for a 1 1/4" pin.
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Fiat 800E/ AgriPower 8000 Tractor for parts. Engine burned, but didnt get the injection pump or hydraulic pump. Back end of the tractor still ok, sheet metal is still there. Good for parts. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
