Company Logo (800) 853-2651 Shop Now
1953 vac-14 depth control valve(srings)
will in texas
08-13-2014 11:19:38
i know it sounds silly but i have taken apart the depth control block and the srings on the pressure valve and releif valve wich one goes where their is a thicker one and a thinner gauge one then i found the spring on the check valve is broke i am going to need one of those springs needing info. please help
CHinNY
08-13-2014 19:01:47
 Re: 1953 vac-14 depth control valve(srings) in reply to will in texas, 08-13-2014 11:19:38
Will I can"t help you with this but you had some parts for sell do you still have the fuel tank?
will in texas
08-14-2014 04:24:51
 Re: 1953 vac-14 depth control valve(srings) in reply to CHinNY, 08-13-2014 19:01:47
yes sir i do you can call me 1-254-913-0159
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
