Case Tractors Discussion Forum |
CASE SC
Author |
[Modern View] |
jimbob09
08-09-2014 13:46:29
I NEED SOME HELP! I just bought another 1950 SC and have been doing normal maintenance, tune ups, and fixing leaks. It starts up on first push of starter button but I am having problems with adjusting the carb. Tractor runs great with no load or in lower gear, but if I try to start out in 3rd or fourth gear it dies. The intake manifold is cold and sweating. I have adjusted the carb to the specs in the Service manual and even opened up the load adjustment about half a turn more. I need some advice from someone more experienced on these carbs and engines. Like I say I own 2 of these SC's and really like them. I am going to make one just for pulling and the other to restore and use around our property. So any help would be greatly appreciated!!! Thanks jimbob09
wilson ind
08-10-2014 07:54:45
Re: CASE SC in reply to jimbob09, 08-09-2014 13:46:29
Had same thing on engine recently. Weak mag with cracked coil.
fixerupper
08-09-2014 22:08:32
Sometimes a weak spark mimics a lean mixture. My SC carb sweats until it's warmed up even on warm summer days and in the winter it's pure white frost. It's the nature of the beast.
Jlwin
08-09-2014 20:27:47
Check the timing my sc did the same found it had backed off a couple degrees.
Christopher Mikesell
08-09-2014 20:21:01
The first thing that I would check is the governor. If the governor is working properly, I would then check the acceleration circuit in the carb. I would loosen the throttle lever and run the speed up and down quickly. If it doesn't tolerate this, then I would remove the main jet and check the acceleration holes. If it will quickly respond to throttle movements without a problem, I would then check the intake/exhaust manifold for internal leaks by backing off the tappets to close the valves and pressurizing the intake side. If there is a noticeable hiss in the exhaust side, then you have found your problem.
08-09-2014 20:43:38
Re: CASE SC in reply to Christopher Mikesell, 08-09-2014 20:21:01
Some sweating on the outside of the intake manifold is normal, especially in humid or cold conditions, and before the tractor has warmed up.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
John Deere 820 tractor in very good condition.2 owner tractor with original rear tires. 715 853 3669
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
