Case Tractors Discussion Forum |
900 b engine miss
Author |
[Modern View] |
Derekburkhart
08-07-2014 09:52:14
Hi y"all, This is my first diesel tractor, I had just bought the other day, brought it home and started up, right away I can tell that there is a miss on one cylinder. the guy I have bought it from said it ran fine which I"m not sure if that"s true now. I didn"t take it down the road a little ways and it was still missing. the only time that would hit on all 6 cylinders is when I would wrap it up. and no I have not done any filter changing just yet. where and how do I start to check into this miss!? Thanks
LenND
08-07-2014 13:37:07
Re: 900 b engine miss in reply to Derekburkhart, 08-07-2014 09:52:14
If the miss disappears after the engine runs awhile check the center head for a leaking head gasket. This is a common problem with the 900B especially if it had been run overheated a few times.
Derekburkhart
08-07-2014 13:41:01
Re: 900 b engine miss in reply to LenND, 08-07-2014 13:37:07
the miss does not go away… but what would be some other symptoms of a blown head gasket?
oldproudvet
08-07-2014 10:34:27
I, too, would want to check valve adj. I bought 401 a while ago for parts because the owner couldn't shake a miss. After filters and putzing the cyinder was quickly located by loosening injector lines. It turned out to be the ex valve on #3. The adj nut had backed all the way out and the valve couldn't open. He'd run it that way so long it ruined the cylinder.
Derekburkhart
08-07-2014 10:45:30
Re: 900 b engine miss in reply to oldproudvet, 08-07-2014 10:34:27
Is the adjustment under the valve cover or a side cover!?
Derekburkhart
08-07-2014 10:24:28
I left out the squeaking noise on the left hand side of engine. Does it 50% of the time.
John Saeli
08-07-2014 10:16:51
Could be many reasons. Not being there & hearing the miss, the easiest place to start is to change the fuel filters, although the fuel pressure gauge, if working will give you the filter condition. Next up would be a check of valve adjustment. If going deeper is needed, pull the injectors, check compression & injectors. If all that checks out, need to look @ the pump. Roger Link has a NOS 6 CYL pump listed in the classified ads, for the earlier 900's.
Derekburkhart
08-07-2014 10:03:37
I ment rev instead of wrap
TexasCC
08-07-2014 10:29:40
Re: 900 b engine miss in reply to Derekburkhart, 08-07-2014 10:03:37
While the engine is running, loosen the nut on the injector lines one at a time. When you get to the cylinder thats missing, the sound of the engine won't change as much.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
