case 530 air cleaner
Anonymous-0
Just pulled the cup off the oil bath air cleaner to clean it .I know
there are two bowels but what is the big flat rubber piece with the
hole in the middle for and exactly where does it go?
This piece is about 5" in diameter with a 1.75 round hole in the middle.Must have been inside the bowel somewhere.
This was inside the bowel on the bottom of the oil bath air cleaner .I took the bowel off to change the oil in it and when I came to put the bowel back on I se this stuck to the bottom of the pipe in the air cleaner.Looks like the bowel had it pushed up tight to the bottom of the pipe.
