Case Tractors Discussion Forum |
Wiring 540C Airport Tug Case 1963 tractor Frontend Loader
Author |
[Modern View] |
slverwey
06-20-2014 19:55:47
I just bought this frontend loader tractor case 540C I have the shop manual C-202 there are no wiring diagrams. The positive lead from battery is hooked to the tractor frame and not the starter. the red wire from the Alternator was cut I re connected and it got hot and started to melt the wire. The manual says the pos lead is to ground and black to the starter??? Battery will not charge? It needs a lot of TLC but would like to restore it if possible??
Anyone got any wiring diagrams and any Idea's Scott
slverwey
06-21-2014 19:35:58
Re: Wiring 540C Airport Tug Case 1963 tractor Frontend Loade in reply to slverwey, 06-20-2014 19:55:47
I posted 3 pictures. I have the positive lead going to the starter and the negative to ground. The red wire to the alt does not get hot and melt any more and the amp/volt meter works now. Lets hope it keeps the battery charged as I had it on a charger.
slverwey
06-21-2014 07:11:43
The battery was already hooked up when I bought it but there was a red wire coming from the alternator and a red coming from the cab off the volt meter which looked like they were twisted together at one time. so when I twisted them back together they sparked and got hot so I took them apart and put a wire nut on each then taped up the ends.
I will be asking tons of questions as the shop manual (C-202) does little help. I have two levers on either side of the steering wheel the one on the left is the throttle but what is the one on the right? It goes to a small box on the back of the engine or on top of the transmission? It does not move very much but it looks like it moves a plunger on this box, is that the case o matic?
Paul A Young
06-21-2014 06:46:18
Re: Wiring 540C Airport Tug Case 1963 tractor Frontend Loader in reply to slverwey, 06-20-2014 19:55:47
Most old generator systems were pos. ground, but when you convert them to alternators negative ground is the way it should be wired.
slverwey
06-21-2014 06:36:03
Is there a way to tell if there are diodes in the alternator I'll take some pictures and post them if I can.
DKase
06-21-2014 06:53:34
Re: Wiring 540C Airport Tug Case 1963 tractor Frontend Loade in reply to slverwey, 06-21-2014 06:36:03
All alternators have diodes. If you hooked the battery up backwards, even momentarily, you likely already smoked the diodes. Hook it up negative ground and see if it charges.
shinnery
06-20-2014 23:26:16
Scott
99.7% of alternators are designed to be wired negative ground. You will have to have special diodes in the alternator for it to work as positive ground. If you have an alternator check very carefully before you wire it and a battery to a vehicle.
Joe Young
06-20-2014 20:03:54
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
