Helped a neighbor replace the cracked block in his 1030. Found the crack in the upper counter bore of a cylinder when we were refinishing the counter bores. It could probably be fixed (expensive?). He intends to haul it to a scrapper next week unless someone is interested in it.
Re: 1030 engine in reply to nna, 06-14-2014 12:06:10
Cracks in counter bores are common and nothing to worry about after truing up. A major machine shop like Abraham's Mach., Davenport Iowa could replace counter bore.
I too found a crack in the upper counterbore of a 1030 block. I made vertical supports out of cast iron & tapped them in place under the lower lip of the counterbore. They extend from the lower edge of the upper counterbore down to the top of the lower counterbore. I am confident it will work. Still re-building it. Don't let him scrap that block!!
Today's Featured Article - Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to
... [Read Article]
Latest Ad:
JD 420 -430 crawler 3 pt. center link 3 parts
[More Ads]
