guys : working my skid steer today and all of a sudden lost my right side drive. hose"s ok and oil level were it should be. the left side works as it should. my guess is the right side drive motor, have any of you guys had something like that happen and be something else? i have not got to start taking anything apart yet, hope to get started on it monday night. thanks for any help.
Re: 1845c skidsteer in reply to urbancase, 06-01-2014 19:07:37
Pull the seat up and move the lever, make sure the linkage is hooked up to the hydro & the spool is moving going into the hydro. Next pull the front chain case cover up, there are 3 chains in each side of a 45. 1 on each drive sprocket & 1 for the gear reduction drive. Check that there isn't a broken chain. Next pull the cover off between the wheels, it is a bearing support for the drive motor shaft, have someone start it and push the lever ahead, the splines on the drive motor shaft and inside of the chain drive sprocket can wear out if it is a high houred machine.
Check to make sure that the parking pin is not engaged. Sometimes the cable will break going between the lever you push down when youre in the seat and that pin.
If when you push the right side drive lever it does not load the engine, disregard the above.
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
