Case Tractors Discussion Forum |
picking up a tractor.
Author |
[Modern View] |
axe55
05-28-2014 22:43:58
Once again I need the forum's help . The vacmI'm buying is within a hr. from where I live. The engine is free. Should I try to start it there ? New plugs fresh gas check points etc or winch it on my car hauler? I will probably have to remove the belly mower.to keep from dragging on the trailer. I need to check out the front wheels may have to buy rims before moving it. Just realizing what you guys go through when buying tractors. Thanks in advance john
axe55
05-29-2014 16:32:01
Re: picking up a tractor. in reply to axe55, 05-28-2014 22:43:58
Thanks for the great ideas . I didn't think about the issues. Any other pre start/driving ideas?
C. Amick
05-29-2014 09:12:37
The pistons may be free, but you could still have a stuck valve and bent push rod. I would winch it on the trailer.
Paul Searl
05-29-2014 08:15:07
We always cringe a little when the seller says" I tried to get it started" on stuff that hasn't run for many years. Since our Rock Islands are allmost all 80+ years old you never know exactly what you will find. Our routine if its not running (and usually even when it is running) when we buy one is winch it on, no attempt to start. Aside from giving a crank to check if stuck and compression we don't actually like to get things moving until its home. once home, dad immediatly changes the oil and checks oil filter. 90% of the time with older tractors the oil is BAD. Sometimes with water in it just from sitting so long. We actually bought one advertised as a full engine overhaul that had old nasty oil and the original accordian style oil filter still in it :roll: . Anyway, its good to flush them out well and get any crud etc out that may have accumulated over the years. No sense running it all through what may have been an ok engine. Ours are pretty easy to check the transmission oil as well. make sure theres not water in it. If we think its been sitting a while, we usually just go straight anymore to taking the gas tank off and cleaning it, flushing the lines and a quick disasembly and cleaning of the carb. Dads kind of gotten in the habbit of pulling the valve covers and checking them as well before we try to start it. once once all that is done, we usually feel safe in giving a couple of cranks. if we don't get anything then we start on mags and spark plugs.
axe55
05-29-2014 00:47:56
1031d I sent you a pm on external_link about the rims ,do you still have them ?.
Straw Boss
05-29-2014 00:19:09
Bring a few planks or plywood pieces along to put under the mower deck so it can slide over the trailer and not get hung up. Wouldn't worry about the rims or tires. Very little weight to a VAC. Shouldn't take much to pull it on.
1031D
05-28-2014 23:48:38
Winch it up dead and take it home. Once home then you can look over any problems and get it running again.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
