Case Tractors Discussion Forum |
Case 446, no fuel to carb.
Author |
[Modern View] |
hparri
05-20-2014 09:34:46
I have a 1983 case 446, with an Onan engine S/N, D803520319, carb M/N DD-DA7E. The fuel pump in integrated with the carb, so I cant by pass it with an after market. I can't find a rebuild kit, or replacement carb. Can anyone help me with info?
JimEvans
07-17-2014 18:40:21
Re: Case 446, no fuel to carb. in reply to hparri, 05-20-2014 09:34:46
You might want to replace the rubber line from the tank, it could have a pin hole in it letting the pump suck air. I do have a inline pump on one of my 444s. I needed to cure a vapor lock problem when mowing on hot days. That did the trick plus it starts almost immediately now instead of having to crank it enough to pump fuel to the carb.
hparri
07-17-2014 07:26:09
the briggs after market pump didn't work, so I took the original pump apart and with a wire I bent the reeds back into position so they would close. Now it works like a charm, just purrs. Thanks for the replies they were helpfull. Oh and I'm not blowing my tractor, LMAO!
Kevinstuff
05-21-2014 09:28:46
You can find parts at Cummins dealer if it"s an Onan, last kit I bought was $56.00 or just get Briggs external pump and place that inline
oldmisterbill
05-21-2014 04:36:30
John I won't laugh at you. I've done that many times over the years for various engines. The worst part is "ring around the mouth".
John Saeli
05-20-2014 17:24:42
Laugh all you want boys, but here is how I start a CASE Lawn Tractor after sitting long periods. Fill the gas tank, take a deep breath, blow into the tank & hit the key. Works every time & won't have to do it again till next Spring.
Klyde
05-21-2014 04:32:07
Re: Case 446, no fuel to carb. in reply to John Saeli, 05-20-2014 17:24:42
Yup, forgot about the Monica Lewinsky service calls!!
Chuck Machinist
05-20-2014 18:18:45
I'd pay good money to have Chris take a picture of you doing that John. HAR HAR!
John Saeli
05-21-2014 05:50:34
Re: Case 446, no fuel to carb. in reply to Chuck Machinist, 05-20-2014 18:18:45
Klyde brings up a very good point. A picture of me in a very compromising position like that would be very valuable. Possibly enough for me to take Chris on a cruise. However, I would never break my vows to the brand I grew up with & perform such a service on another brand. A picture of that would command many $$$.
Klyde
05-20-2014 16:17:40
I"ve worked on them since they were Colts, cheapest way out is to put an inline primer bulb in the gas line(like on a outboard motor). most times the pump will pump if it has fuel it just won"t suck it up. Check for flow out of the tank, a lot can happen in 30 years line could be pinched, cracked, or the screen elbow in the bottom of the tank could be completely plugged. That carb has been a nightmare for the last 10 or 15 years! Parts are a small fortune. I have found a few online. What you need is a blanking cap to go inplace of the pump and then either a electric or the impulse pump off a modern briggs or kohler. hth
maxwell99
05-20-2014 13:56:10
I have the same tractor mower, with same engine. My local caseIH dealer carries many parts for the tractor. It's worth a call: Mckeel tractor co. Murray, KY. They have been a case dealership for many, many years. Current owner/manager said in days gone by a customer was always asking: if I buy a new combine or large tractor will you throw in one of those case mowers, he said most customers did not understand what high dollar machines these mowers were even back in the day. Hope they can help you.
casecollectorsc
05-20-2014 09:45:47
You can put a small inline pump in the fuel line under the tractor. I think the smallest pressure you can get is 6# pressure. Need a good needle and seat to hold the pressure. We have done that on a couple 446.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
