Hey Guys, On the hydraulic dipstick the little full/add indicator is halfway between the 1 and the 6! This doesn't seem correct. I talked to John in NY and he said that it should be up by the 1. The indicator seems pretty solid in that position, I can't slide it with my fingers. I'm worried that if I grab it with a pliers that it will eventually slide back down and fall off into the hydraulics and cause major problems. Is there any reason why I can't just take that piece off and use the indentions in the dipstick for oil level?
Also, I have the big 'Yoke' style western hitch on my 930. The top part is welded SOLID not bolted on. My operators manual says that you should NOT use pto powered equipment with this style hitch. That is a real bummer, considering I bought the tractor for field work and cutting and baling hay! Any ideas? Can I go to a bone yard and find a straight hitch from a 30 series tractor that will bolt on? I really have no use for a western hitch. Thanks, Dan
