Case Tractors Discussion Forum |
Case 4694 Engine
Author |
[Modern View] |
Frank Depuydt
02-11-2014 19:55:50
We have a Case 4694 with 10,000+hours on it that we use for spring and fall tillage. We bought the tractor in Jan 06, it never seemed to have an abundance of power and smoked excessively black. In the fall of 2012 it spun a rod bearing. The Winter of 12-13 We completely rebuilt the engine; new sleeve assemblies, new injectors, had the pump rebuilt with new barrels, new turbo. Spring of 2013 it smoked even more and does not seem to have the power it should. This winter we have double checked the valve timing; valve movement distance,as well as the pump timing; put a intake manifold from a 2470 for testing purposes, and it still seems to be the same. It only seems to build about 6 psi of boost. Any Ideas?
cshess
02-12-2014 17:23:05
Re: Case 4694 Engine in reply to Frank Depuydt, 02-11-2014 19:55:50
Check the fitting on all the connections where plastic connections are. On our 4690 a reinforcing ring that is used to keep tubing fromcolapsing had turned 90degrees an was blocking air flow. Been a while but fitting was near radiator cross over.
rdl
02-12-2014 13:18:13
We always set the pump timming at 31 deg.BTDC,I think the original spec was 25 deg.BTDC
Jeremy McNary
02-12-2014 06:45:41
I agree with the others,it sounds like you have a severe air blockage some where, also you may want to look at the turbo itself and make sure that it is working properly as you should have alot more than just 6 pounds of boost.
dwag
02-12-2014 06:44:25
Rent a timing light from Spencer Diesel (712)262-5267 Actual/running timing prob off 5 to 9 degrees from static. Joel at Spencer's will explain the situation, john
Mike S806/h
02-11-2014 21:01:42
take the inlet tube with the precleaner off and clean it out, my 2470 had the same problem, on the dyno it only had 90hp and smoked like a profarm tractor puller! mine was plugged with a mouse nest,
111
02-11-2014 20:28:39
I have a boost gauge in my 1570, have never loaded it right down but it will make at least 25lbs under a good load. Ben
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
Looking for two coulters and mounting brackets for a JI Case centennial plow
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
