Case Tractors Discussion Forum |
For Agri King
Author |
[Modern View] |
Dodgeit
11-13-2013 05:54:06
The tractor is a 700 Gas.
The rules are typical
Drawbar not more than 20" high, nor shorter than 18" from center of rear axle.
Wheelie bars not more than 10" off the ground, must support weight of tractor.
10% over stock RPM
Tire sizes based on weight class. I run 16.9 x 38 could run 18.4 in the higher classes.
Stock block (or replacement), heads, intake, exhaust, distributor ( electronic ignition conversion allowed, such as Pertronix).
No side shields, unless they were OEM at time of manufacture.
Weights on brackets cannot be past the rear wheels and no closer than 4" from the closest part of the tire or rim. Weights cannot be more than 11' from the center of the rear axle on the front bracket.
Speed limit 3.5mph or 4mph depending on club, those without a horn on the sled limit you to first gear for stock classes.
Rear tires cannot be wider than 96" outside to outside.
No Aluminum rims allowed for stock classes.
I think that covers it.
Agri King
11-13-2013 17:38:48
Re: For Agri King in reply to Dodgeit, 11-13-2013 05:54:06
Thanks for the info. I have a 800 gas, 700 diesel & a 400 gas. The 400 gas isn't running (yet). One of them needs something fun to do. I'm guessing your 700 is close to farm stock?
Dodgeit
11-14-2013 08:57:26
Re: For Agri King in reply to Agri King, 11-13-2013 17:38:48
I removed the eagle hitch, hydraulics and p/s pump. Bumped the engine from 251 to 267. LP heads and manifold were already on it. run 16.9 x 38s on spin out rims 9also on the tractor when I bought her.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
