Company Logo (800) 853-2651 Shop Now
vac positive or negative ground
young tractor
11-11-2013 11:50:28
Hi guys, I have a 1948 vac case and have a question regarding the battery hook up. They are supposed to be 6 volt positive ground right? It is hooked up as negative ground and the negative wire from the coil is going to the distributer. I am putting in a new battery and and want everything hooked up right. If I switch it back to positive ground do I re-polorize the generator. If so, how do I do that. I also would have to switch back the distributer wire to positive on the coil. What else do I have to do? Thanks in advance for all of your help.
young tractor
11-11-2013 18:22:57
 Re: vac positive or negative ground in reply to young tractor, 11-11-2013 11:50:28
Thanks guys. How do I know what my voltage regulator/cutout relay is set up for? I just want to make sure every thing is correct and working. Is there any test for the regulator/cutout relay to know if they are neg or pos ground?
Jerry W
11-11-2013 14:31:42
VAC's were originally positive ground. The only piece in the electrical system that is polarity sensitive is the voltage regulator/cutout relay. You need to wire it so your regulator is happy. If it is positive ground then that is how it should be run.
Jerry
Klyde
11-11-2013 15:52:11
 Re: vac positive or negative ground in reply to Jerry W, 11-11-2013 14:31:42
Also the ammeter is polarity sensitive. It really doesn't care, it will just read discharge when it is charging, and vice versa. If it works right now I would leave it neg Ground.
rvirgil_KS
11-11-2013 13:49:16
It apparently has been running with it configured for negative ground.
From an electrical standpoint there is no reason to switch back to positive ground. Install the battery with negative ground and it will be right for your configuration.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea ... [Read Article]
Latest Ad: John Deere DUBUQUE Parts for sale- 24 inch power adjust rims, 3 point hitch parts, Utility Rockshaft, Utility Anchor Yoke, 40 Standard ring and pinion, various 40 transmission gears. Other DUBUQUE parts available. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
