Company Logo (800) 853-2651 Shop Now
2294 fuel tank
Jeremy McNary
10-28-2013 08:12:06
whats the process for removing the fuel tank on a 2294? After it got destroyed this morning I was to mad to take much time to look at it. Looked in the service manual but didn't see anything in there about removal.
Jeremy McNary
10-28-2013 16:08:09
 Re: 2294 fuel tank in reply to Jeremy McNary, 10-28-2013 08:12:06
Nevermind guys, after cooling off for awhile I looked it over and figured it out. Wasn't to bad other than the nuts were rusted tight to the bolts and just spun
1370rod
10-28-2013 19:53:43
 Re: 2294 fuel tank in reply to Jeremy McNary, 10-28-2013 16:08:09
When you reinstall the tank tell me what kind of luck you have doing that. To me they always seem to big and it's hard to get those rear retaining brackets back on, Rod.
Jeremy McNary
10-29-2013 13:51:29
 Re: 2294 fuel tank in reply to 1370rod, 10-28-2013 19:53:43
You were right Rod, not real fun to put back together for something that seems so simple. The first bracket I put on brought out the sailor in me lol. For the second one I opened up the bend a little got the bolt in the top hole first and then pushed and beat the bottom in with a 2 lb deadblow hammer until the holes lined up.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
