Case Tractors Discussion Forum |
Case VA
Author |
[Modern View] |
Ry8N
09-28-2013 17:17:59
Just bought a 1951 Case VA with an Eagle Hitch in decent shape. I've spent years working with 8Ns and MH TO series, so am not familiar with these types of tractors. Just put new wires, gauges, steering wheel, alternator and some other stuff onto it, and am slowly hammering out the dents in order to repaint it.
I'm looking for parts if anyone has anything kicking around they want to sell. Needs a PTO shield and possibly a new radiator.
Also seems to be a problem with the flywheel as I can't get it to engage (was told there's a broken pin inside), and a rear wheel is leaking oil.
Can anyone here offer any tips on using these types of tractors and fixing them? I am not at all familiar with using the Eagle Hitch, so don't know if there are any tricks to it. I'm planning to plow, disc and brush hog with it, but not much else.
Ry8N
10-05-2013 05:22:58
Re: Case VA in reply to Ry8N, 09-28-2013 17:17:59
Turned out to be the carburetor was clogged up with gunk, so tore that down and cleaned it good - now it runs great!
Now back to repainting... Anyone recommend vinyl vs mylar decals?
Ry8N
10-03-2013 17:13:10
Thanks for the link - that's a very helpful site.
Now seem to be having a problem with getting gas to the carburetor, not sure if the float is clogged or what. It'll fire up when I spray ether into the carb, but die shortly after, and carb is dry as a bone.
paul f
10-04-2013 07:07:46
Re: Case VA in reply to Ry8N, 10-03-2013 17:13:10
Is there gas in the glass bowl under the tank? Sometimes the garbage they sell for gas these days can plug up the tank outlet
C. Amick
10-01-2013 17:41:52
Try peepertractor.com for parts. You might find the web site below handy. To engage the belt pulley. loosen the set screw and shove the pulley toward the tractor.
paul f
09-29-2013 06:37:55
I much prefer my VAC to my brothers 8N. The live hydraulics are a big plus...just wish it had a live PTO. Not sure what you mean by the flywheel not engaging. If you mean the starter motor pinion gets stuck or wont engage them you ring gear is bad. The ring gear on mine looks like new except for one section about 3 inches long. that is really chewed up. Engines choose to stop at the same point most of the time. You can dress the teeth up with a file.
Christopher Mikesell
09-28-2013 20:22:28
First, the eagle hitch has no draft control. It is just an up/down lift with a quadrant that can be used to set the depth/height. Also, there is no side-sway, as the eagle hitch arms are rigidly set at 28" on center. This means that you might need to do some minor adapting to your implements to make them fit. That is, of course, unless they were originally made to work with the eagle hitch.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Implements and Their Use - by Curtis Von Fange. Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he reached his early sixties
... [Read Article]
Latest Ad:
WANTED, Minneapolis moline G 955 or G 1355 LP or diesel. Call and let me know what you have for sale.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
