Company Logo (800) 853-2651 Shop Now
** La ** water pump .. I think .. pic
Dutchman
09-14-2013 17:00:57
third party image
third party image
Last time I went plowing in the fall around 40 degrees .. my La started to run HOT .. so after a 1/4 mile of plowing ... I had to pull off to the side and let it cool down { left it run } YES the lovers were WIDE OPEN .. so I just was thinking may-be rust and stuff got the bottom neck partially plug .. took the neck off today and stuck a hose in top , not much but a little color water came out .. flush for 10 min. or longer WHAT would you think ,my problem could be ... hoping to do some plowing again this year .. fan belt is new and tight { move it 1/2 inch , but not more than 1 inch .. Thinking it might be the water pump .. can they be rebuilt ... or do I need to start looking for a new one .. THANKS for any and all the information you will share with me ..
..... ..... .. mark
SDLars
09-15-2013 06:21:04
 Re: ** La ** water pump .. I think .. pic in reply to Dutchman, 09-14-2013 17:00:57
Just to chime in on my experience and to agree with casecollector, when I went through my LA and now my L, it's unbelievable how much crud was in the radiator tanks, head and block. I flushed and blew rust out of the block especially for about a week. That stuff is bound to plug the tubes. It just happens after they sit long enough, especially dry. Wish I would have kept track of how much junk I flushed out.
casecollectorsc
09-14-2013 19:28:56
May not work for everyone, but like I said in an earlier post we have had good luck using "The Works" drain cleaner and work the tractor and flush. The cast iron tanks on the D LA etc. flake off and plug the tubes. If a guy knows what he is doing he can use stronger muratic acid, but too much could be a problem.
El Toro
09-14-2013 18:59:46
Hi Mark, That's nice looking soil you're plowing.
When the engine gets hot touch that bottom hose on your radiator lightly to see if it's hot. If it doesn't appear to be hot your radiator tubes may be blocked from crud. Be careful not to burn your fingers. Hal
C. Amick
09-14-2013 17:24:19
Not trying to be smart and it's probably not the problem, but I would take the metal Case sign off the grill. I'm sure it's blocking some air flow.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
