Company Logo (800) 853-2651 Shop Now
Serial numbers for 1170
elkcagg
07-26-2013 19:38:39
Did some searching here on YT for serial number breaks for the 1170 and Im somewhat confused. My 1170 has a tag with 237**** number. The parts catalog states it should be either before or after 8675001 ? Not making sense here....
elkcagg
07-26-2013 19:42:04
 Re: Serial numbers for 1170 in reply to elkcagg, 07-26-2013 19:38:39
Whoooops. I think thats the transmission serial number I mentioned?
Case Nutty 1660
07-26-2013 19:41:21
how many numbers have you got? sounds like you missed the first one or two they are hard to see some times let us know
elkcagg
07-26-2013 19:44:28
 Re: Serial numbers for 1170 in reply to Case Nutty 1660, 07-26-2013 19:41:21
7 numbers on a plate by the right brake. 2370786
Case Nutty 1660
07-26-2013 20:10:49
 Re: Serial numbers for 1170 in reply to elkcagg, 07-26-2013 19:44:28
that sounds like the trans serial tag tractor serial is above the LH step right above the floor board below the black panel that has 451 cubes I can take a pic of one to show you if you can not find it
cnt
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
