504 transplant question
I have a tired 504bd in a Case loader that needs replacing or rebuilding block casting #a66526. I found a good running case 504bdt that has block casting #A58516 and it looks older than the engine I have but runs very well. Will this engine swap?? Any help is appreciated. Thanks.
Any 504 will bolt in where one came out. The BD and BDT would mean non turbo and a turbo'd engine. There will be internal and external differences in the engines, but as far as installation they will bolt up the same. Rod.
Rod, I did not comment as I was not sure on the crank bolt pattern as some "BD" have the smaller rod/main brgs but I thought all 504's had the same pattern
cnt
