Company Logo (800) 853-2651 Shop Now
DB 990 Implematic head gasket?
P White
07-08-2013 18:04:47
The other day i noticed the engine oil level was high and a milky color. checked the rad and anti freeze is low. I am thinking head gasket but is there any way to tell? Is there parts available for this , it has the AD4/47A engine? This is bad timing , I need this tractor to cut hay in a couple of days. I am going to change oil and drain anti freeze and fill with just water to hopefully get by.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
