Case Tractors Discussion Forum |
This showed up in my yard yesterday
Author |
[Modern View] |
Adirondack case guy
07-07-2013 16:09:40
        An aquaintanance of mine stopped by last week, asking about a 530 that he was looking at. Asked him a few questions and determined that it was a late 530 row crop, with DOM. He said the seller had put all new clutch plates into the PTO, but wouldn't stay engaged. He said that he could buy it for 3K. He drove it up here yesterday afternoon, only about 4 miles. Bro and I talked about it this morning and determined that it was a very early 68 model. The PTO is really screwed up, as it won't turn when pulled forward and won't lock over center and it takes a 16" pipewrench to turn the shaft with the lever in any position. 3PT won't drop, (perhaps stuck hold valve), as rockshaft is free. Lefft brake a bit weak, but not adjusted up to the RH one. Both work decent. John S., looking for a Tach and cable for it. plus may need some other parts. I will call you this week. There are some things different about this very early production 68 541. Draft armes may be after market, as they have combo CatI and CatII balls on the ends, and appear heavier than the Case arms. Also someone may have altered the foot throttle, as you need to put your heel on it to operate it. It actually works pretty good. The row crop axles were weak on these tractors and the pic. shows how a lot of them riped open on a spiral. The 440/540 ylilized the same axle components, but the geometry was much diferent, to lower the profile. Loren
Bruce from Can.
07-08-2013 08:31:06
Re: This showed up in my yard yesterday in reply to Adirondack case guy, 07-07-2013 16:09:40
As I recall, my 430,that I once had, had a foot feed the same. Except it was turned so that it ran under the break peddles, ant not beside the trany. Bruce
Adirondack case guy
07-08-2013 09:45:50
Re: This showed up in my yard yesterday in reply to Bruce from Can., 07-08-2013 08:31:06
Hey Bruce, Is it still raining up there. since memorial day it has rained every day except 3 back in late June. Supposed to get some gulley washers this afternoon. They say the jet stream is going to change a bit by the end of the week, and bring in some less hot and humid weather. You are correct on the foot throttle, and there is another hole in the floorboard to rotate it under the brake pedals. As I mentioned, it wouldn't take much to get use to it in that position. We will see what the customer wants. Loren
j hikemper
07-08-2013 06:37:13
that 530 would fit rite in at this place,,, typical STRANGE AILMENTS of all sorts, too .., that ft feed like that would give me nite cramps and leglox in my calfs,,if I spend along day on the dc , I suffer same pain ,, but that's just me ,, I would bet the pto has some backwards parts ,,,is itpossible case offered the swivel 3 pt arms ,,, seems like ihave seen that before on some ones tractor
Bret4207
07-08-2013 06:18:11
I'm interested in hearing about the PTO fix. I had the one off my 811b apart and near as I can tell it "should" work, But no matter what I do it won't overcenter. I end up sort of jamming it in place but that's a poor way of doing things. I've adjusted it till I'm blue in the face per the manual but I think the springs are shot.
4x4stude
07-07-2013 21:53:23
Very nice! I hope you get all of the issues fixed easily. I have a 1966 530 that is in peices and I hope it will look as good as that one. My front axle looks the same as that on. Mine has a loader on it which I am sure contributed to it's demise! Zane
Farmallb
07-07-2013 19:27:53
Question. Why do you keep referring to it as a row crop when it is clearly a wide front end tractor??
Glenn F.
07-07-2013 20:11:26
Re: This showed up in my yard yesterday in reply to Farmallb, 07-07-2013 19:27:53
If the front (and rear) axles are adjustable, it's a row crop tractor. Glenn F.
marsh_31
07-07-2013 20:08:05
Row crop simply means the wheels can be adjusted to different row widths, regardless of wide/narrow front. What I'm curious about is why they have the left side slid clear in and the right side out? Nice looking machine anyways, hope the issues can be solved.
55 50 Ron
07-07-2013 20:33:35
Re: This showed up in my yard yesterday in reply to marsh_31, 07-07-2013 20:08:05
it's actually two different front ends in the two photos, I believe.
Vito
07-07-2013 16:49:50
I had a 730 diesel with a COM that had damage like that to the front end.Whoever repaired it did a good job.Should have never let that one leave as it ran real nice.If I keep lurking on this board I might have to add one to the herd.Been thinking about it anyhow.Too many dorfs may not be a good thing. Vito
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner.
... [Read Article]
Latest Ad:
International 140 runs excellent very nice original tractor with original back tires. Always barn kept full set of cultivators. Tractor comes with original drawbar and cultivator wrench. Serial number 63788 hard to find one this nice. Delivery can be arranged if not to far out.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
