Case Tractors Discussion Forum |
Tie mech on 1960 140 W Case Bailer
Author |
[Modern View] |
Farmallb
07-01-2013 15:23:34
I was advised to come over here with my problem. The tie mech on my bailer was worked on b y mechanics. Im supposing a spring finally broke, and that let the clutch dog b e at the wrong place at the wrong time, and it broke. I had another junk 140 and took them both to the mechanic. He fixed THAT problem, BUT, as I was turning it to time it, I noticed the needles wouldn't move. I took the side plate to the tie mech gear box off and cleaned out the grease and oil. I found there are 3 set screws/bolts on the bevel gear on the main shaft. The gear turns but the shaft dosent. I found these set screws/bolts are spaced the same apart. What im needing to know is IF the shaft has indentations to accept the set screws/bolts or how do I make sure the shaft is in the right place. if ive just got to retighten them? Thanks ALOT for any help.
4435
07-01-2013 21:19:01
Re: Tie mech on 1960 140 W Case Bailer in reply to Farmallb, 07-01-2013 15:23:34
I have a parts donor sitting in a shed The cover was already off and unfortunately the set screws are already out for some reason. I could turn the sprocket on the gearbox and the plate with timing boss on it would turn. I could only see a bit of the shaft thru the set screw hole but saw no marks or indentations. Tom
Farmallb
07-02-2013 06:12:07
Re: Tie mech on 1960 140 W Case Bailer in reply to 4435, 07-01-2013 21:19:01
Thanks. I don't see tho, how you could see anything through the bevel gear, as to whether it had indents or not. Im going to take one of the sets out, and put a wire in the hole and try to turn the shaft. That way ill be able to tell if it has the indents or not. If it does, Im a lot better off. IF not, im not, THO I think that the Pitman arm has to be in alignment with a bolt on the cam when its where the cam needs to be. Ill try setting the gear by that and see what happens.
Farmallb
07-02-2013 08:37:42
Re: Tie mech on 1960 140 W Case Bailer in reply to Farmallb, 07-02-2013 06:12:07
I just took the chain off from the tie mech to the flywheel. I put a hammermill belt on the flywheel and to my 48 H Farmall. I let it out on idle and walked back to look. Everything was turning. except the cam. I noticed I hadn't put the pin bolt in that holds the dog, so I did that. Then I flipped the dog by hand and it worked perfectly. THE SPRINGS EITHER SLIPPED OFF OR BROKE AGAIN. I cant get the cam off, and I couldn't the first time. Hate to take it off, it weights a lb or 100. Hate to haul it back to JD again. Ill have to impress on them that the slipping off of that spring, or the breakage of it can cause the needles to crash, and as of 4yrs ago, there were only 16 in existence at $186 a pop.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Implements and Their Use - by Curtis Von Fange. Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he reached his early sixties
... [Read Article]
Latest Ad:
WANTED, Minneapolis moline G 955 or G 1355 LP or diesel. Call and let me know what you have for sale.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
