Trying to shred...the pto does not keep turning correctly in thick weeds. As i understand it my problem will be one of these..
1. hydraulic pump/pressure---assume this is good since batwings raise as does the shredder. Not slow, seems to work normally.
2.control valve
3.cable that works the control valve---with the pto disengaged the shafts on the shredder will still slowly rotate.....guessing that if the cable was not tight eneough this would not happen.
4.Pressure plates----how hard of a job is it to do?
anything else im missing or i need to know about?
2.control valve
