Case Tractors Discussion Forum |
Case 680C
Author |
[Modern View] |
Philip Schemanski
06-24-2013 12:50:35
I have a case 680c backhoe. The backhoe has been sitting for many years, I have just finished fixing the hydraulics now my problem is with the hydrostatic transmission. When I first start up the tractor it will move forward and backwards fine but only for a short time 1 or 2 minutes, I then have to shut it off wait 30 seconds only, and start it up again and it will move forward and backward but only for a couple of minutes. I have drained the fluid and replaced it. Fluid was a nasty milky lumpy stuff. The backhoe was sitting for about 5 years which before that it worked fine. Is there a filter or screen that I could replace or clean?
Philip Schemanski
07-01-2013 04:35:42
Re: Case 680C in reply to Philip Schemanski, 06-24-2013 12:50:35
The transmission screen was clogged. Cleaned it up and backhoe works fine.
Thank you guys so much. I finally got an easy fix for something.
The fluid was a little milky still hopefully this second drain and refill will fix that.
Philip
Philip Schemanski
06-27-2013 11:12:59
Re: Case 680C in reply to Don Rudolph, 06-24-2013 12:50:35
Thank you for your reply I will check this week end to see if I can find that screen. Thank you.
Philip
A. G. Keiper
06-24-2013 20:33:04
I think Tom is right. There is a cylindrical screen that lies in the bottom of that shuttle housing. It runs from front to back and you remove a pipe plug then pull it out and clean it.
Case Nutty 1660
06-24-2013 13:50:20
its been 40 plus years since I serviced a 680C,, it will have a trans filter not sure if it is by the trans or mounted by the engine, is the oil foamy when it quits? or still milky/dirty? sounds like it may be covering the suction to the pump and you are loosing clutch pressure, again it has been many years but does it have a pan on the shuttle you can remove and clean/check the screen
Philip Schemanski
06-27-2013 11:10:20
Re: Case 680C in reply to Case Nutty 1660, 06-24-2013 13:50:20
It doesn't have a pan but it does have an access plate bolted on the right side of the transmission. I made a quick look and didn't see any filter, I will look better this week end and I didn't look at the fluid. I will do that this week end also. Is there a way or a fluid to flush the transmission?
Thank you for the help.
Philip
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
A 1937 John Deere Unstuck - by Gary Hickman. Here is my story of how I got the pistons out of a 1937 JD B that the engine had been stuck for about 14 years: About 12 years ago my Dad gave me one of the tractors I ran as I was growing up on our farm in central Nebraska. The engine on this tractor, a 1937 John Deere "B", had been stuck for 2 years before he gave it to me. This last spring (1999) I hauled the tractor to our 2 acre lot in St. Libory Nebraska where it joined my antique machinery collection, at that time a 1929 Caterpillar T
... [Read Article]
Latest Ad:
M 5 moline.. 336, good TA , 16-9 38 tires..fresh paint PS photos on request....nice 3 point tractor with strong hydraulics new battery and service
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
