Case Tractors Discussion Forum |
case 970 wont idle down
Author |
[Modern View] |
steven in tn
06-19-2013 23:20:53
i have been tinkering with my 970 i just bought and cant get it to idle down below 1400rpm. the foot pedal sticks when i push it and have to pull it up with my hand. i have sprayed everything i can see but still didnt help the pedal comes back alitte bit on its own now. but even pulling it up with my hand will only go to 1400rmp. and the hand throttle doesnt do much till allmost wide open postion and then it will go up to 2000-2100rpm. anyone have a diagram on how all the linkage and cables run so i will know where to spray all the moving points?
ranchingelec
06-20-2013 18:36:56
Re: case 970 wont idle down in reply to steven in tn, 06-19-2013 23:20:53
I have taken out the front right cab mount bolt, disconnected the linkage under the foot pedal. Then I could put the unit into a vice and loosen the pivot rod that was rusted up. Lot of work but the results are rewarding. That is if the pedal is rusted. Ranch
j hikemper
06-20-2013 04:53:17
sounds like you got a rusty one ,, as mel said operate manually the lever on the pump ,.and see if it will idle back .if rust is problem , while you are spraying joints and pivots , you mite pull shifting beauty cover off and spray all the cables and pivots in there ,, my 1070 was neglected before I found it ,,the pshift was about the only thing that was not stiff ,,, oiled everything up including the horizontal range shifting collar shaft under platform ,, sure helped it a bunch.
mEl
06-20-2013 04:05:10
Did u disconnect the rod at the pump to see if it idles down then? The pump has a lo idle adjustment that could keep it running to fast if it has been changed, Otherwise, you have the pivots at each end of the throttle shaft and the hand and foot throttle linkage behind the engine and not much more.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
