DairyFarmerInMA
Hello,
a while back ( maybe a year ) you posted some pics including a 200b (I think) with a hydraulic post hole digger/auger on it. The auger was I think being run by a front mounted hydraulic pump usually used for a loader. My question is where did you plumb the suction side from on the torque tube and where is the return line ( from the non factory open center valve) dumping the oil back into the torque tube? Is it as simple as the drain plug and fill plug? I'd like to do something similar for my 3 pt wood splitter so that I have the option of using the splitter without the loader on.
Thanks
always enjoy your posts
-Will
Thanks
-Will
