Author |
[Modern View] |
Agri King
05-23-2013 05:28:37
    With a late spring here in WI. I got to use some Case forum idea's. Went digging in my grainery-o-parts and found 2 radios to make 1. The steps are off a 2090. We revamped the steps to angle them toward the doorway and move the steps out from the cab a couple inches. The factory duals I took to a wheel shop and they cut the 16' wide rim off and welded a 18' rim on for the 20.8 38's. I replaced the fuel tank because the steel filler insert had come loose. I have installed a number of these aftermarket tanks, and they seem to be well made. If the fuel sender fits. Lol.
Jgarner
05-25-2013 07:40:58
Re: Past Case Forum Post Idea's in reply to Agri King, 05-23-2013 05:28:37
What's that green thang there in the background. (<: Jim
Don Rudolph
05-23-2013 19:58:27
Eric, I sure like the improved steps idea. I'm going to try that on my 1175, as soon as I get done planting. Thanks for posting pics. Don
Agri King
05-24-2013 05:19:29
Re: Past Case Forum Post Idea's in reply to Don Rudolph, 05-23-2013 19:58:27
Don, Got some pics of another set of 1175 steps someone did. I'll see if I can find them.
Ande
05-23-2013 14:28:26
The "1175" always had that "get out of my way" look.Very nice.
Kow Farmer
05-23-2013 12:23:38
Eric, That 1175 looks great. I'd like to find some steps like those for my 1070 someday. Hope all is well at your place. Snow gone yet? LOL Kow Farmer Kurt
Agri King
05-24-2013 05:15:54
Re: Past Case Forum Post Idea's in reply to Kow Farmer, 05-23-2013 12:23:38
Kurt, It did snow hard for 5 minutes mothers day weekend!
Case Nutty 1660
05-23-2013 07:54:29
McKerrow630
05-23-2013 07:41:20
AK, I don't know much about the "4-diget" series. The upgrades you have done look good and appears user friendly too. Thanks for sharing
1370rod
05-23-2013 05:54:52
Eric I would sure like to find another working radio like that, to last 2 I got have been duds. I have never used a aftermarket fuel tank yet, but it sounds like you give them thumbs up. Rod.
Agri King
05-24-2013 05:11:56
Re: Past Case Forum Post Idea's in reply to 1370rod, 05-23-2013 05:54:52
Rod, The tanks are well made. For the most part. Instead of the rubber inserts in the bottom of the tank these have brass pipe fittings molded into them. The radio I found in a New Holland swather at the salvage yard $25. Yea, they are hard to come by, being 35 plus years old and all!
