daviddg
New User
Wondering where the master cylinder filler cap for the brakes on a Case 580B is located. Thanks to someone who can tell me the location.
sounds like you need to pull the brakes and see what needs replacing, I can post you breakdowns on where you can start looking, there is also a adjustment under the tractor on the brake linkage, basic;ly you will need to replace the balls/springs and lining wear parts,,, will try to post what you need if no one else has them handy cnt
If you get in to it and need some parts I might have some I could let you have reasonable. I'm putting brakes on a 580CK right now and acquired some extra parts. The left side was corroded up pretty bad. The right side I think the linkage just needs freed up.
