urbancase
well guys i think i found the problem, it was what THAD said about rain water got in from the air cleaner. i started taking it back apart tonight and when i pulled the air cleaner off my leg got wet, when i got the air intake tube off the side and i looked into the middle head it was full of water. so when i tryed to start it yesterday it just sucked all the water in and blew the new gasket out the side of the block. i am going to take the head up and have it checked to make sure it is all right. i also checked from the top edge of the sleeve to the top of the piston and i have a .005 diffrence between pistons 3 and 4, i was checking to see if i bent a conneting rod. i think that is ok but you guys tell me what you think as i am not 100% positive. i did not have the metal cover over the air cleaner on mine tractor yet and all 3 tabs are broke and i was looking for a way to fix it, i guess i should have layed it on there when it was parked. does anyone know why case made the 1570 with the top of the air cleaner with out a real cover, i have a 2470 and the air cleaner on that one has a top that seals like most air cleaners do. i want to thank all you guys for the help.
