Company Logo (800) 853-2651 Shop Now
Hey ACG Loren?
560farm
04-16-2013 15:59:08
Hi Loren,
If I understand you correctly from the archives, to change out the brake shaft seal on the big 400 into the 30 series. I want to leave the diff carrier/brake pad plate fastened and go inbetween it & the shaft to remove old seal and cover splines to install new one the same way correct? I have the parts breakdown but hadn't read the service manual yet. For all the Cases we have this is the first one I've had to do:-) Thanks
Brad
Adirondack case guy
04-16-2013 17:24:49
 Re: Hey ACG Loren? in reply to 560farm, 04-16-2013 15:59:08
You have the details correct, as long as there is no play in the diff. carrier shaft, and side gears. If there is looseness in this area you will need to pull the PTO housing to acess the ring and pinion and first preload the diff. shaft and then remove and install the quill shims from side to side to get proper gear lash on the ring and pinion. Should be about .002-.004", but if there is ware that can be hard to measure.
Pry out the old seals if things are OK and protect the new seal with something over the brake disc splines. Tape, thin plastic, or peice of tin, and lube will work. Case dealers had a seal thimbell that slid over the splines and then you slid the seal over that. Hope this answers your question. My case friends may also have further advise.
Loren
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
