I just bought a CaseIH 2096. When U your drivng it in push in the clutch the tractor stops real quick almost as if you pushed in the break lever as the same time. And now 1st and 3rd don't work on the powershift. Also the diff lock did not work so I replaced the rocker switch and nothing. Help?
Re: CaseIH 2096 Shifting issues in reply to Jeff Loidolt, 04-14-2013 09:01:27
Check the c1-c4 swap switch. This switch is controlled by the clutch pedal movement. Listen close while you slowly push the clutch down. (engine stopped of course so you can hear) As you push the clutch pedal down you should hear a click when the pedal is 1 inch from the top of clutch travel and again when the pedal is 1 inch from the bottom of its travel. The c1-c4 swap switch is the bottom switch. Hopefully this is your problem.
Re: CaseIH 2096 Shifting issues in reply to james Aakre, 04-14-2013 10:25:21
Last winter I did an 1896 that only had reverse,all three swap switches had corroded fast at the hinge and stuck the switches. New switches renewed to normal operation. The relay boards can fail but a lot less common, get a can of PB Blaster and work the little stitch levers while spraying the pivot at the bottom of the lever till it movesw freely. hope that fixes u up. mEl
Today's Featured Article - Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
