I have a case 2470 that steers well and runs through the gears
well. The problem is that it has 4 remotes and they are
sluggish or useless unless I move two of the levers at the
same time. Then they will lift the implement as though there
was no problem. Issue is that I have to let go of the steering
wheel to lift the implement! I would suspect the pump but it
steers well and lifts implements when two levers are engaged
in opposite directions. I would suspect the remote but all four?
I appreciate any suggestions on how to start the
troubleshooting process. Thanks.
