Company Logo Shop Now
Case 970 Broken gears found in Hyd oil change
cbrown
04-09-2013 06:11:05
ok, i am changeing the hydraulic fluid in my case 970, and have found some broken gears that came out of the drain plugs, is this a huge issue, what should i be looking for, also the power steering works, but feels somewhat slugish, i feel like i should be able to keep turning the wheel with minimal effort and have the front wheel move, instead if i stop turning the wheel for a second and start turning again it turns with ease, thanks in advance
RGMartin
04-10-2013 06:59:24
 Re: Case 970 Broken gears found in Hyd oil change in reply to cbrown, 04-09-2013 06:11:05
It is a common Delco/GM starter. Any good starter shop should have it. While you are at it, you could have the shop build you a 40 series starter for it, if you are in a cold climate, it will be a big help.
fastline
04-09-2013 15:37:55
As you probably have figured out, it might be just as smart to refresh the oil and filters and run some good systems checks. If everything operates as it should, RUN IT! No way to know where the trash came from but you might be on a wild goose chase otherwise.
I never like that unknown feeling but it could save you a LOT of time to ignore it unless other signs show up like more chucks or debris in the filter. Also, this might be one of those times where a scope could come in handy! Get in there and look around a bit to see how things look. Won't give you the full story but only other option IMO is a complete tear down and inspect/replace it ALL. Bearings, gears, shafts, bushings, mic it all and figure out what you bought.
I am playing that game as I type...... :D
rdl
04-09-2013 15:31:14
Could be from a starter drive that failed
cbrown
04-10-2013 04:30:14
 Re: Case 970 Broken gears found in Hyd oil change in reply to rdl, 04-09-2013 15:31:14
didnt even think of that it looks alot like a starter gear, ill look at my starter, but im guessing it may have been from an old one
cbrown
04-10-2013 06:52:20
 Re: Case 970 Broken gears found in Hyd oil change in reply to cbrown, 04-10-2013 04:30:14
i have confirmed that its from an old starter drive, same shape off an old starter as mine has all teeth, also the teeth on my new one are getting wore, can you buy just the drive gear
cbrown
04-09-2013 10:15:53
third party image
third party image
third party image
i believe it came from 3rd drain plug from front, the bottom most hole had some metal filings but no big chunks, the hyd filters the 25 micron had filngs in it, should i replace these in near future as well as know like know and 30 hrs from know it is a power shift trans
brokengun
04-09-2013 10:57:52
 Re: Case 970 Broken gears found in Hyd oil change in reply to cbrown, 04-09-2013 10:15:53
I’m not the best person for diagnosing a broken piece of gear but it looks like to me that it’s either a piece of spider gear or a gear for the hydraulic pump drive.
Do you know the history of the tractor?
It is possible the tractor had a gear failure at one time in its life and that’s just a piece of left over gear that’s made it to the drain hole.
cbrown
04-09-2013 11:32:35
 Re: Case 970 Broken gears found in Hyd oil change in reply to brokengun, 04-09-2013 10:57:52
no history, bought it at an auction it wont get hard use from me, but i dont want to fix it constantly, im very big on proper maintenance
DKase
04-09-2013 08:08:21
Power shift? Gears, or springs and steel scraps? If power shift, and if spring parts + steel scraps that come out of the front plugs it would most likely be pieces from a previous torque limiter failure. If gear parts it could be very serious.
cbrown
04-09-2013 07:43:40
also is it possible that the gears are from the hydraulic pump, or are they trans gears
Adirondack case guy
04-09-2013 08:04:02
 Re: Case 970 Broken gears found in Hyd oil change in reply to cbrown, 04-09-2013 07:43:40
We need a description of the broken parts, or better yet a pic. there are lots o gears in the tranny o a 970. Is it a PS or 8spd. What compartment did the peices come out of. There is a good chanch that your whole hydraulic system is contaminated, and that is causing your steering problems.
Loren
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
Latest Ad: 560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
