Company Logo (800) 853-2651 Shop Now
broken brace
kregw
02-06-2013 04:39:34
Hi, not sure what it is called, but on my 47 VAC, there is a brace under the motor that the front end connects too with a pin, well I broke it, need a name of part and where I may find it.
Thanks
Stephen Newell
02-06-2013 15:04:57
 Re: broken brace in reply to kregw, 02-06-2013 04:39:34
third party image
If this is it,the guy wants $45.00 for it. Link
kregw
02-06-2013 15:34:07
 Re: broken brace in reply to Stephen Newell, 02-06-2013 15:04:57
Not it but thanks any way,
kregw
02-06-2013 14:57:24
third party image
Pics
Adirondack case guy
02-06-2013 15:17:16
 Re: broken brace in reply to kregw, 02-06-2013 14:57:24
After seeing the pic, I would suspect that Fred G would be your best bet.
Loren
Fred Goodrich
02-06-2013 06:48:57
I should have it I am in NY and i ship.
kregw
02-06-2013 08:24:17
 Re: broken brace in reply to Fred Goodrich, 02-06-2013 06:48:57
Great, how much do you need for it?
Adirondack case guy
02-06-2013 06:11:55
There are many variations of VAC front axles. A pic would be extreamly helpful in determining what you have. My first thought would be to have it welded back together. Not quite sure if you are talking about the axle bolster, up front or the pivot bracket for the wishbone, back on the torque tube. You mentioned that you were missing the pin, so I am presuming that you have a tubular adjustable front axle, but there is another adjustable front axle that had different brackets. How did you break it?
Loren
kregw
02-06-2013 06:26:59
 Re: broken brace in reply to Adirondack case guy, 02-06-2013 06:11:55
I think it is the pivot bracket, I broke it by towing the tractor and the person in the truck didn t take the slack out of the chain before taking off.... so my electrical issue has turned into a broken peice issue
Adirondack case guy
02-06-2013 06:26:20
third party image
third party image
Here is a parts break down for the tube type adjustable axle. Does your's look like this?
Loren
kregw
02-06-2013 06:42:08
 Re: broken brace in reply to Adirondack case guy, 02-06-2013 06:26:20
yes, this is it, thanks alot
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
