Company Logo (800) 853-2651 Shop Now
Re: Please help with serial number for an LA Case
Bob
03-27-2001 16:41:21
The serial number on a LA is in two places. The first is on the 'dash board' near the gauges. The second is on the left side of the motor (behind carb) on the flywheel flange. 4862A is not a serial number.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: 2 early 1950s Dodge Pickup Trucks flathead 6 engines 4 speed stepside boxes havnt run in 35 yrs Good restoration prospects or parts Price 600 each can hold till late fall for buyer. calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
