Company Logo (800) 853-2651 Shop Now
Need VAC Seat Identification
Connor9988
01-20-2013 19:19:03
third party image
third party image
Hello everyone,
I have a 1951 Case VAC SN: 5572624
I am wondering if the seat assembly is the correct one for this SN/year. If it is not what one do I need?
If this works right the 1st picture is of my VAC.
The second picture is of another VAC with a different seat assembly.
Thank you.
1031D
01-23-2013 07:21:26
 Re: Need VAC Seat Identification in reply to Connor9988, 01-20-2013 19:19:03
Minn-Kota rebuilds them or you can use a certain Oliver spring as I do, but they only have 2 pins instead of 3 to hold the gear racks, never had a problem yet.
rbradk
01-22-2013 02:25:28
2nd. picture is of a case easy ride seat assembly. Option for the tractor. I have one that came on the tractor originally.
1031D
01-21-2013 10:54:21
Connor, where do you call home?
Connor9988
01-21-2013 11:28:00
 Re: Need VAC Seat Identification in reply to 1031D, 01-21-2013 10:54:21
Southern Missouri. More Specifically the Fort Leonard Wood area.
Shoot me an email.
Case Nutty 1660
01-21-2013 06:27:01
third party image
third party image
found this lit sheet for you
1031D
01-21-2013 05:57:47
That grill is for a VA or VAI. I have a friend looking for one of those. He is by Rockford somewhere. The second seat is Oliver. I have a freshly rebuild tall Bostrum seat but they're not all they're hyped up to be.
Connor9988
01-21-2013 09:03:20
 Re: Need VAC Seat Identification in reply to 1031D, 01-21-2013 05:57:47
Well Sir (if you are not using your tall Bostrum seat) would you like to make a trade for the VAI grill? I can throw in the short Bostrum seat assembly that I have since I have no use for either.
If not I understand.
Thanks.
Connor9988
01-21-2013 00:21:05
third party image
Okay, Thank you all.
By the way, does anyone know which model this grill goes too? I purchased it thinking it would fit my VAC but after a closer look found out I was wrong. I think its for a VAI but am not sure.
B A Star
01-20-2013 21:28:42
   My comment below is meant for he second set of photos.
B A Star
01-20-2013 21:26:29
   The seat in the second photo is from a fleetline Oliver tractor (66, 77 or 88).
Connor9988
01-20-2013 20:58:14
third party image
third party image
Thank You! I have been trying to figure that out for some time.
Okay so the next first picture is of a seat bracket I bought from a sale for my VAC. Im guessing its for a VAC 14 and wont work? (or at least wont look right since its shorter.)
The second picture is of another seat mounting bracket I could have bought. What is this and is it possibly for a VAC?
Now that I know I'll probably stick with the original but I'd still like to know about these others just in case I change my mind later.
Thanks!
Jgarner
01-21-2013 10:44:20
 Re: Need VAC Seat Identification in reply to Connor9988, 01-20-2013 20:58:14
The first seat was used on the early 530 and 630 for sure, same as the one on my 630, don't know if it went on the 430 or not.
Jim
Christopher Mikesell
01-20-2013 21:29:12
Yes, the seat in your first picture looks to be from a VAC-14. However, the second seat is not from a case. It may be from an Oliver, or John Deere, etc. Many companies used rubber torsion springs in the 1950's.
As far as I know, the torsion spring seat on the VAC was never an option. Early ones came with one like the one on your tractor and later ones came with the torsion spring style. I have never seen picture of a VAC with the new style sheetmetal which lacked the torsion spring seat. It is possible that the seat and sheetmetal did not change at the same point in 1951, but I doubt it (CaseIH just changed their website parts section, so I can't check their free manuals to be sure). Probably, the torsion springs went bad and the owner replaced the seat with the older style, rather than rebuilding the seat and replacing the expensive springs. I have seen at least three SC and DC tractors in the past year which have had this treatment (they are more of a problem when the springs go bad than a VAC is).
Fortunately, most of the parts are the same between the VAC-14 torsion spring seat and the VAC torsion spring seat. I think that only the lower weldment (which bolts to the tractor) is different.
1031D
01-20-2013 20:21:36
The first picture is the original seat that would have came standard, the second seat is a rubber torsion spring seat made by Bostrum and was an option. You could also buy it as a replacement for the older models.
will in texas
01-23-2013 06:56:16
 Re: Need VAC Seat Identification in reply to 1031D, 01-20-2013 20:21:36
on the rubber torshion springs do they sale replacements for the vac-14 mine are bad any help would be great thanks will in texas
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
