Case Tractors Discussion Forum |
Case 800 ?
Author |
[Modern View] |
Earlj
01-08-2013 16:59:00
I have an 800 bought not running it is a diesel I put an 830 injection pump on it and been completely through engine. My question is how do these tractors sound, this one reminds me a little bit like a 2 JD cylinder at idle, rev up still kind of hear it, wide open and loaded it sounds ok and runs fine, is this how these old diesel sound or do I have a problem? I did also turn fuel screw back as far as I could, still smokes plenty. Thanks for any help
Lazy WP
01-09-2013 11:54:44
Re: Case 800 ? in reply to Earlj, 01-08-2013 16:59:00
I would make sure the compression release isn't hanging up. I only gave $400 for mine 5 years ago, and at an idle, it blows white smoke, and misses something terrible. I need to check the valves, but for no more money then I have in it, I'm not messing with it too much. Once its warm, I think it will out pull my 830, at least traction wise.
John Saeli
01-09-2013 06:45:45
When everything is right, she should click 'em off like a sewing machine. If it sounds like a 2 banger, and you are sure of the adjustments, my next step would be a compression check.
Case Nutty 1660
01-08-2013 17:04:42
no they should not sound like a two banger JD, my guess is you have the timeing wrong or the pump is not working as it should and or maybe the valves not set right? the 267 dsl should run smooth hope this helps cnt
Earlj
01-08-2013 17:12:48
Re: Case 800 ? in reply to Case Nutty 1660, 01-08-2013 17:04:42
Been Through the timing and valves twice all checks out ok, also I tried the injection line crack to isolate the miss each line made a definate change. Only ? would be operation of pump. Also noticed the rain flapper it never bounces like its missing just has the stranger flutter sound in the exhuast
Case Nutty 1660
01-08-2013 17:23:56
Re: Case 800 ? in reply to Earlj, 01-08-2013 17:12:48
Hmmm did you have the pump/injectors checked out or do you know they are good condition also? not sure what to make of the fluttering sound with out actually hearing how its running maybe a few others will chime in with more ideas
Just Thinkin
01-08-2013 17:36:11
Re: Case 800 ? in reply to Case Nutty 1660, 01-08-2013 17:23:56
Make sure the rocker arms are not in contact with the compression release system.
Earlj
01-08-2013 17:29:46
Not sure about pump it was off a junker, injectors have been rebuilt, I am unable to youtube wish I could. I wandering if the different shape manifold had something to do with it, Reminds me of a header.
Adirondack case guy
01-08-2013 17:20:04
Can't hear it here. Perhaps a Utube link so we can hear it running. Loren
Case Nutty 1660
01-08-2013 17:24:33
Re: Case 800 ? in reply to Adirondack case guy, 01-08-2013 17:20:04
we are doing it again Bro LOL
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
