Case Tractors Discussion Forum |
TSX 616 body size ??
Author |
[Modern View] |
Dodgeit
12-29-2012 18:00:43
IS the 616 a medium body or Large body MS carb?
Dodgeit
01-03-2013 08:48:11
Re: TSX 616 body size ?? in reply to Dodgeit, 12-29-2012 18:00:43
mE1 email sent in reply to your suggestions.
mEl
01-02-2013 15:07:32
Thanks for all the replies.
I put a 1-1/16 venturi in and gained 10 cfms @ 10in-hg. What else needs to be done to feed a 267 ? The restriction seems to be the carb so far. The heads and intake manifold flow close to the same, with a slight edge to the intake (1cfm). The carb needs 10 more cfm to be equal to intake ports.[/quote] If you have a lathe get a piece of 1.5 brass or aluminum stock and make a bigger one. 1.125 may put you where you want to be. Just try to approximate the shape and the internal taper of the original. Relieve the outside as there is a passage in the front that needs airflow from the rear for the idle circuit. I make straightwall venturis at 1.300 and there's room for a bit more but I modify the carb upper body so that passage can get air by another route.
mEl
JT's RandR
12-30-2012 19:25:15
The tsx 616 is a big body carb if I remember correctly. It should be the same size as the zenith modle used. Checking with the gaskets in a kit wont do much good because they include the small and large gasket in them because all the other components interchange. If your looking for more hp You can take a venturi for a U Moline and put in the 616 and get an extra 10 hp.
mEl
12-31-2012 03:59:00
Re: TSX 616 body size ?? in reply to JT's RandR, 12-30-2012 19:25:15
JT, you wouldn't know the size of the U venturi would you? The 830's used a 1 1/16 venturi and that is what I use for a stock DC when converting them from the Zenith. For pulling I always felt the Zenith with the booster venturi was somewhat restrictive at higher rpms.
For bigger CID applications I make my own venturii which seem to work very well if the fuel circuits are modified to feed the extra airflow.
On what application were you getting 10 hp for a venturi change, that's interesting. 10 hp is a nice gain from a simple venturi change!
I know a DC likes a MS carb with a 1 1/16" venturi. A well setup MS gives a couple more hp but the engines idling characteristics are much improved.
The bodies with a bolt on inlet will bolt directly to a DC air cleaner if you want an original look.
mEl
Dodgeit
01-02-2013 12:43:54
Re: TSX 616 body size ?? in reply to mEl, 12-31-2012 03:59:00
mEl
12-30-2012 11:36:42
Quoting Removed, click Modern View to see I don't know specifically what body size that is but, the large carb as used on the 400 800 830 etc measures 1.437 at the bore for the butterfly. That is the carb I use for my more stock performance applications. Motec engineering can answer your question if you do not have the carb apart to measure it. mEl
old
12-30-2012 10:46:24
I am sorry I can not tell you which size it is but you might try this to find out. Go to an auto parts store like O'Reilly's and if they have the kit on hand you can look at the gaskets in the kit to see if it is the big or medium size body carb. Just an idea for you so you can find out since no one has answered you
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
