Hope you guys don't tire of me showing broken stuff out of CASE tractors. When it seems to be a uncommon failure I'll probably post it. I posted a pic of a trans housing full of filings a couple weeks ago. I had a couple jobs more urgent to finish first. Now I had a chance to see were all those filings came from. The pins that hold the diff spider gears had worn so bad and so thin they actually broke in 3 pieces as you can see. On the bull pinions or side gears, call them what you like, have all the end teeth worn off, a good gear is there to show the difference. In my 40 yrs. of wrenching this is the most damaged one I have seen. These parts are out of a 1070. This diff assembly had to have been repaired once before because of the brass pins it contained. From the factory these tractors had steel pins. If a failure occured it was common in this area to upgrade them to brass pins from the 1170 tractors. Rod.
