Author |
[Modern View] |
shinnery
12-10-2012 01:47:20
shinnery
12-10-2012 22:43:28
Re: 1370 at auction in reply to shinnery, 12-10-2012 01:47:20
Well I thought the rear tires were about worth the current bid. I know if they were 15.5-38s I could get interested in it. It is less than 300 miles from me. And someone might be able to use some of the rest of it.
Bryce
dan walsh
12-10-2012 17:52:06
looks like a 1175 to me. it looks like it has outboard plantateries
Case Nutty 1660
12-10-2012 18:18:23
Re: 1370 at auction in reply to dan walsh, 12-10-2012 17:52:06
those are Factory Case weights I have a pic of them some where cnt
dan walsh
12-10-2012 18:26:47
Re: 1370 at auction in reply to Case Nutty 1660, 12-10-2012 18:18:23
It would take 2 men and a boy to put on, ha. How much did they weigh?
Case Nutty 1660
12-10-2012 18:53:42
Re: 1370 at auction in reply to dan walsh, 12-10-2012 18:26:47
they are darn heavy I thought they were 600-800lbs each but it has been a long time since i seen one cnt
B A Star
12-10-2012 09:48:30
I know a guy that bought a JD 4440 on an auction and was told it had transmission concerns. Got it home and took cover off and the only thihg inside was the two rear axles.
RGMartin
12-10-2012 09:06:00
If it was close by it would be interesting. If there was a lot wrong in the back end, I'd build some sort pf hybrid out of a good 8 speed back half I have here.
Idaho spud
12-10-2012 07:17:12
You could put more into that tranmission than the tractor worth if you got it for nothing. Believe me I know by experience.
Glenn F.
12-10-2012 05:09:13
Rich10e
12-10-2012 05:32:47
Re: 1370 at auction in reply to Glenn F., 12-10-2012 05:09:13
Must have tranny troubles,it has a block in front of the wheel
