Case Tractors Discussion Forum |
1290 crank swap
Author |
[Modern View] |
farmboyWI
12-07-2012 14:01:08
Finished a rebuild on this engine using some .040” over pistons, but couldn’t get it to start. Started thinking low compression and did a little investigating. This tractor has the 195 engine, turns out I have pistons for the 219 (1/2” longer stroke on the 219 so these pistons are ¼” too short for the 195). Case can’t get oversise pistons for the 195, so we tossed around a few ideas, and unless someone here knows where to get some .040” over pistons for a 195, we’re going so swap the crank from our burned-out 1394’s 219. It looks like the dimensions are all the same but does anyone here know for sure?? Also, would there be any fuel pump issues going to a larger displacement? Just want to have an idea what I’m getting into before I tear into it. By the way, I work at an engine machine shop, so any machining and such is not an issue. Thanks! P.S. I’m looking at rebuilding that 1394 (“Smokey”), if possible using the crank from this 1290. Anyone know how much power you can get from a naturally aspirated or turbo’d 195?
Thad
12-07-2012 14:19:28
Re: 1290 crank swap in reply to farmboyWI, 12-07-2012 14:01:08
The crank will fit fine. We have switched many 990s over and never had any trouble. We did one for my brother and it seems to run even cheaper than the 195 on fuel with the 990 pump. As far as pistons i think i have a real good set of used .040s in the back somewhere. I could look if you were interested in them. Thad
Thad
12-07-2012 14:21:07
Re: 1290 crank swap in reply to Thad, 12-07-2012 14:19:28
On the pistons you should be able to find new ones aftermarket. Thad
RGMartin
12-07-2012 14:27:19
Re: 1290 crank swap in reply to Thad, 12-07-2012 14:21:07
Must have both been typing at the same time. BTW, the drop box gear works perfect.
RGMartin
12-07-2012 14:18:11
Sparex offers .040" pistons for the 4/49 engine. I just bought a set this summer. $55 or so each, very good quality, made in England. Same piston that late 990s used. http://v2.gb.sparex.com/ItemDetails/ItemDetails.aspx?ItemNumber=57514&OriginalItemNumber=&CurrentTab=ModelCompatability#TabsThe parts guy at your Case dealer needs his butt kicked for selling your the wrong ones. A 1394 crank will drop into your 1290 fine so long as you are sure you have the 4/55 pistons. No issue with the fuel system. As to power out of a 195, how fast do you want to run it? How many mods do you want to make? In stock form, you can get 60hp just by letting it run as fast as the 4/55s run.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
John Deere 820 tractor in very good condition.2 owner tractor with original rear tires. 715 853 3669
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
