Company Logo (800) 853-2651 Shop Now
Case 410 tires
BLC
11-27-2012 11:03:58
So looking for some help with my 1956 410 Case. The rear tires on it are in poor shape and need replacing. Currently it has 14.9x39 6ply on there but judging by the Operators Manual it should have either 12x38 or 13x38"s on it. How do i know what to size tire to replace my current ones with? Will the 12x38 and 13x38 fit the same rim and if not how do I tell which size rim I have. Sorry for all the questions but this is my first tractor so I"m at a bit of a loss in figuring this out and in a machine thats 58yrs old I need some advice. Thanks!
jon f mn
11-27-2012 12:37:36
 Re: Case 410 tires in reply to BLC, 11-27-2012 11:03:58
Measure your rim width from bead to bead, that will be the info you need to determine which size tire you will need. The 400's that I've seen have been pretty evenly split between 14.9/38's and 15.5/38's. They take different rims and you never know if the tires on there are the right ones. So just measure your rim and ask where you buy your tires which size is right.
Jharn57600
11-27-2012 12:18:19
Link
You will find that a 14.9-38 tire is the same size as a 13-38 was in 1956.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
