Case Tractors Discussion Forum |
steering u joint removal CASE 400
Author |
[Modern View] |
jon barton
11-23-2012 16:23:17
i am working on a CASE 400 DIESEL... i am trying to convert it from manual to power steering by swapping parts from 2 case 400's. i can't see how to unhook the u joint just under the radiator so the steering unit can be removed from the front tub. i can't see a pin or set screw or anything...is it screwed onto the shaft? can anyone tell me how to separate the long shaft from the dash.. from the short shaft that enters the front steering unit? thanks for any help
Jim from Cal
11-23-2012 18:40:06
Re: steering u joint removal CASE 400 in reply to jon barton, 11-23-2012 16:23:17
Case really made an engineering goof on the 400 which they corrected on the 800 and 700.. {more on this later} (1) first remove the roll pin in the U-joint. (2) loosen the 4 bolts holding the pedestal to the engine ..about ½”. (3) Pry the pedestal about ½” forward (4) remove the u-joint from the PS unit. I have rebuilt 4 case PS motors in the past two years and the 400’s require the pedestal moved forward in order to remove the u-joint. On the 700/800, the pedestal is about ¾” longer and thus the u-joint can be removed without moving the pedestal.
Doc Larry
11-23-2012 16:34:43
I don"t remember the exact details, but I, too, had a devil of a time getting that u-joint out when I replaced it....
jon f mn
11-23-2012 16:30:07
The front u-joint has a roll pin in each side threw the joint and shaft along with a half moon key. I've never found an easy way to get any of this apart. You will have to take the 2 bolts that hold the bushing bracket below the fuel tank off.
jon barton
11-24-2012 22:17:59
Re: steering u joint removal CASE 400 in reply to jon f mn, 11-23-2012 16:30:07
i found the roll pin and was able to get it out and tap the joint off the rod by taking the bolts out of the bracket under the gas tank. thanks for all the advice!!
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to
... [Read Article]
Latest Ad:
JD 420 -430 crawler 3 pt. center link 3 parts
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
