Author |
[Modern View] |
Die Hard Case
11-06-2012 16:57:11
I am looking to bore our 451bdt to a 504 is the crank in 451 the same as 2670 crank or should I just look for a the so call big journal 504?
Die Hard Case
11-07-2012 15:39:18
Re: 451 vs 504 crank strength in reply to Die Hard Case, 11-06-2012 16:57:11
Thanks guys this is for a pulling tractor. The tractor already dynos out at over 300 with the 451 but I plan on doing more exstensive engine work to get to the 600hp range and I was just worried about the smaller crank taking the extra rpms and heat. So if I find a good crank out of a 15 26,2590 or 4690 it will go right in my block without any machining the block? I would just like to do this the right way the first time. Thanks Jason
Thad
11-07-2012 16:14:30
Re: 451 vs 504 crank strength in reply to Die Hard Case, 11-07-2012 15:39:18
No a large journal crank will not fit your block. Thats what makes them stronger is the larger journals. You just need to find a complete 504 from the models you just posted. This will give you the later screw in injector heads also. Your smaller crank has 2.75 rod journals and 3 inch mains. The larger crank is 3 inch rod and 3.5 mains. Thad
1030 TOM
11-07-2012 06:01:42
I have got a 1030 with a451 out of a 1175 this tractor makes 168 hp on two diferent dynos ran it for 10 yrs never no trouble dont know if it would live any higher good luck
RGMartin
11-07-2012 05:48:53
Have you ever seen a broken crank on a "farm use" small journal that wasn't turned up or abused?
1030 TOM
11-07-2012 05:22:05
friend of mine made a pro stock puller out of a451 lasted 3 pulls he went to a504 crank has lasted 3 yrs
1370rod
11-06-2012 17:26:33
Bingo, get a later 504 with the larger crank. These blocks also give you the piston cooling oil spray which helps the engine live at much higher HP. Will need the bigger oil pump also. 504 blocks in 20 and 2290 tractors had the small crank like the 451, Rod.
pump ?
11-07-2012 17:46:47
Re: 451 vs 504 crank strength in reply to 1370rod, 11-06-2012 17:26:33
The oil pumps are differnt between the engines?
1370rod
11-07-2012 19:52:04
Re: 451 vs 504 crank strength in reply to pump ?, 11-07-2012 17:46:47
The engines with the piston oil spray use a higher volume pump. Example 20 and 2290 with a 504 have the small crank and smaller oil pump, 23 and 2590 have large crank high volume pump and oil spray. The 1470 had large crank, no spray and small pump. Early 12 small crank, small pump, no spray. Late 12 had small crank ,BIG pump and spray. Are you confused yet? Early 13 was like the 14. Late 13 all 15,24 26, 23,25, 44, 46 all had big crank, big pump and spray. Rod.
Die Hard Case
11-09-2012 17:13:48
Re: 451 vs 504 crank strength in reply to 1370rod, 11-07-2012 19:52:04
I have a 1470 engine that I have acces to would it be better to find a 504 with the oil spray to take the extra heat or just put the high volume pump in ad call it good? I plan on rebuilding the motor anyhow I not that sure if it will create that much heat in one pass down the track to hurt anything too much. Any input is always helpfull Thanks guys Jason
Thad
11-08-2012 03:11:30
Hey Rod i didnt think the 1270s ever had piston cooling on them since they were all 451s. But i dont think i ever worked on a very late one either. Thad
1370rod
11-08-2012 05:47:57
Re: 451 vs 504 crank strength in reply to Thad, 11-08-2012 03:11:30
I was surprised to see that also, it would be to only non 504 engine that I know that had it, Rod.
