You actually have a model "BL" plow, or B-series "light". Tail wheel was not common on the one bottoms. Frame should be IH red, axles Hunter (Oliver) green and wheels Euclid green. Bottom should be green also.
It appears that you have a Case Centenial plow, that is missing the rear tailwheel assy., however it has an extended landside, not common to a centenial plow???? Color wise it would be dark green,(Oliver like) with lime yellow wheels, (Euclid Green) Loren
Re: plow in reply to Adirondack case guy, 10-22-2012 17:39:37
Thanks for the input Loren. I'm not sure but on other non tailwheel plows that had a option, leaving off the tailwheel required the longer landside. That's just a observation and not a fact. I'll look alot closer now and maybe come up with a tailwheel. Thanks again, Loren.
Latest Ad:
John Deere wheels rare pair of A1106R 24 inch solid cast rear wheels 3000.00. Pair of BWH / BNH 40 inch spokes 1600.00 pair of John Deere D front spokes 350.00.
[More Ads]
