Case Tractors Discussion Forum |
830 Case - roll pin in throttle lever broke
Author |
[Modern View] |
andy r
10-15-2012 18:27:00
This is an 830 Case diesel. Not a Comfort King. Narrow front, sort of sit lower between the fenders. Fuel tank in front of the steering wheel. Maybe they called them the "high profile Case-o-matic. Anyway, the roll pin in the throttle lever has broke. So, there is the lever, a friction disk, then another little round casting under the friction disk. The roll pin goes through the lever. All of this fits over maybe a 7/16 round shaft coming from down in front of the gear shift levers right above the transmission. I do see the opening with a spring and locking collar that pull down on the shaft to compress the friction disk. My question is - what is the simplest and fastest way to put the roll pin back in??? Seems like the spring is pulling the rod down and making it a little hard. Thanks. andy
j hikemper
10-15-2012 19:26:18
Re: 830 Case - roll pin in throttle lever broke in reply to andy r, 10-15-2012 18:27:00
i hate it when that happens ... it is a PIA to fix ,while ,makeing repair a guy could realize simpler ways to originally build the throttle lever ...
Case Nutty 1660
10-15-2012 18:57:46
the boys gave great advise but so you know that is a sprial heavy duty roll pin, a standard one usally does not last long, in my tool box I think I have some ones from the dealer ship that were solid for some of the harder moving ones we had out cnt
DKase
10-15-2012 18:46:28
Loosen the adjusting nut on the bottom end of the shaft enough to lift the shaft and the roll pin go back in.
andy r
10-15-2012 18:59:53
Re: 830 Case - roll pin in throttle lever broke in reply to DKase, 10-15-2012 18:46:28
Do you have to take the batteries out to do this??? Are you taking about the "adjusting nut" being that collar I mentioned, or are you entirely at the bottom of the shaft?
casecollectorsc
10-16-2012 05:17:51
Re: 830 Case - roll pin in throttle lever broke in reply to andy r, 10-15-2012 18:59:53
At the bottom of the shaft, a nut and a locknut. DKase is right, that's the correct way to do it. I grind down a #60 pole barn spike if you can't get a double roll pin. Like Cnt said, a single roll pin won't last long.
casecollectorsc
10-15-2012 18:44:04
Vise-grip on the shaft right above the steering column bracket,pry bar it up and put in pin.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
