I've given up on the mag that quit on my SC. I bought a Delco angle drive distributor, probably was on a Farmall, but the number matches what many of you use for Case conversions. (I think it's Delco 111141)
My tractor has an old Wagner loader that's been on it from nearly new. So front pedestal has crack/break and former owner put a reinforcing band around there that covers the hole for the crank, (I don't have a crank anyway). (I bought a replacement pedestal to put on later)
I'm not used to doing this or setting up timing, etc. Did a little years ago, but no longer have any confidence. I know there is a little pipe plug below the starter that, when the flywheel is in exactly the right position, will show what the manual says is a dimple, hole or circular mark to indicate, I guess, top-dead-center? I know if I can get the engine turned over to come up on compression for No. 1 cylinder, I'm close. I do have a starter, but it's going to be tough to use that to get precise positioning. I can try to pull on fan belt with all plugs out. If I can get it on top-dead-center, (and not be off 180 degrees), then it seems that if I have the dist drive bolted up with the rotor pointed to No. 1, I should be close to having the tractor fire up. (Provided I've remembered to wire a 12V lead to the coil) By the way, how do I know which dist. cap hole is supposed to be No. 1 in the first place??
I don't have any real assistance nearby, so this is me alone. Any tips on how to make this a positive experience? My biggest concern is finding top-dead-center and how to turn engine and get the drive syncronized.
Thanks for listening,
Dennis in E WA state
